Sony, Panasonic, Tosh Qucik Help
Discussion in 'Blu-ray & DVD Players & Recorders' started by Tobez, Dec 21, 2004.
  1. Tobez
    Tobez
    Going to go buy 1 in 30 mins. just need a quick push which way i should go.
    Can all the above play multi region.?
    Can all the above play -r -rw +r etc IE the panasonic e85 and the 600 quid sony.
    Any pros n cons ?? will they play VCD good are are some of them fussy
    thanks
  2. SDHoward
    SDHoward
    Nov 1, 2004
    250
    I may be wrong.. but if you want multy region on any of these you need to get a moded version.
    as far as the tosh goes, playback of all the -'s fine. It can play back +'s, but it has to be the correct + media burnet the correct way so not really worth counting on.
  3. yhtomit
    yhtomit
    I swapped a Panasonic DMRE95 (V. similar to DMRE85) for a Sony RDR HX900
    because I wasn't happy with picture quality. Panasonic is better for editing,
    but Sony is much better picture. Panasonic does DVD-R & DVD-RAM. Sony does
    DVD+R/RW & DVD-R/RW.
    rgbdirect.co.uk where I got mine did the Sony for £525 inc. delivery and it was a
    multi-region. I am very pleased with it.
    Also soundandvisiononline.com do good prices, but may charge more for multi-region.
  4. Tobez
    Tobez
    Yho i am undecided on the panasonic or sony, i think the sony looks like getting my money
    Whats it like for U know cough VCDs etc ?
    Can you chop up large recordings from the hdisk
  5. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    The Sony does not have a divide function, so you can't take a large recording and chop it into multiple pieces (e.g. to split over multiple DVDs). Both the Panasonic and the Toshiba can do this.
    Mark
  6. yhtomit
    yhtomit
    Yes, this is the problem with the Sony. It didn't matter too much for me since I use
    Sky+ and can easily transfer material in segments from Sky
