Sony, Panasonic or neither
Discussion in 'General TV Discussions Forum' started by wilby, Jun 27, 2002.
Tags:
  1. wilby
    wilby
    Jun 27, 2002
    58
    Yorkshire
    Dear All,
    I've been researching buying a new TV for about 6 months ! and have hopefully reduced my selction (afer looking in the reveiws on this and other sites & mags) to;
    Sony 24 or 28LS35
    Sony 28FX65
    Panasonic 28PL1C or 28PL10
    I've had a 14" Somy for the last 13 years and it's been the BEST purchase I've ever made. I've read about the bar problems with the scrolling bars.
    Which is the best choice? Are any of these TV actually any good or should I stick with what I have? Would Philips be any better?
  2. Jarvo
    Jarvo
    Nov 30, 2001
    16
    Like you I have owned a 14" Sony for some years now and when looking in to buying a 32" widescreen TV last year I was keen to get a Sony.
    To cut a long story short I had to send back to Sony's with Geometry and various other problems and I finally settled on a Panasonic TX 32PK-20 and it's absolutely superb I can't fault it in anyway. I believe the PL10 was a semi replacement for the PK20 so it should be good.
    Go to a shop and get them to play a DVD on the models you've suggested and then decide.
  3. Squirrel God
    Squirrel God
    Also consider the Sony KV28LS60/KV32LS60. I have the 28" version. My review is here: http://www.avforums.com/forums/showthread.php?s=&threadid=37326
    If you watch R1 and/or R3 DVDs, I'd steer clear of Panasonics if I were you as they are prone to moire with NTSC.
    But as Jarvo says, try for yourself. You can't really buy a TV these days without at least checking it out in the shop first ;)
  4. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    Ill add my pennys worth.. take alook at the Toshiba 32ZD26P Take a look at this thread just got this set yesturday and its beautiful
    Paul
  5. wilby
    wilby
    Jun 27, 2002
    58
    Yorkshire
    Thanks you three! I guess I'm going to have and test/look at these in the shops. With only c£700 to play with the Tosh might be out of my range.
    Later.
  6. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    wilby
    There is due a 50Hz version of the new tosh that might fall in your price range the 28 / 32Z23
    Hope this is of some use.
    Paul
  7. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
