Sony Package
Discussion in 'Home Cinema Buying & Building' started by Paul_GPvR, Aug 19, 2004.
  1. Paul_GPvR
    Paul_GPvR
    Aug 19, 2004
    55
    11
    +3
    Hiya,
    I'm totally new to home cinema stuff. But now i have just bought my first house :clap: i'd like to get started :D
    At the moment ive got a basic 4:3 tele with a built in DVD player. Its fairly new and good enough at them moment. Ive noticed its got lots of RCA sockets and a Optical Digital Out hole.
    I will also be buying a freeview box for this soon....(will need help on this later!)
    Basically all i want to do is add good speakers and cinema sound from all angles. I looked into buying seperates ( amp/reciever & speakers) but was starting to get a bit lost in it all. So found this Sony package which i like.
    Sony HTDDW860 Link Here
    What do you guys think? SHould i go for this or something else????
    it will be used for eveything, TV, DVD, PS2, Radio, CD's, MD's etc
    Thanks very much for anyhelp whatsoever.
    Paul :smashin:
  2. Paul_GPvR
    Paul_GPvR
    Aug 19, 2004
    55
    11
    +3
    Ok,
    How about the Yamaha AV-50 (RX-V350 & NS-P100) package or similar? Ideally I’d like a slightly better amp. So id be grateful if you could advise, open to ideas and suggestions. I’m looking around the £300 price mark for AV Receiver and speakers.
    Thanks very much,
