Sony P Series Battery Charger
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Mad Matt, Sep 6, 2004.
  1. Mad Matt
    Mad Matt
    Aug 7, 2004
    14
    Reading
    Could anyone recommend the cheapest place to get one of these? The dual one at the Sony store is £89. Is there a compatible (and cheaper) third party one?
  2. Roy Mallard
    Roy Mallard
    hahnel do a generic sony infolithium charger which has various adaptor inserts to suit all sony lithium batterys, pay around £50 from Jessops.
    This unit has a mains charger and a 12v cigarette lighter adaptor so can be used on the move.
  3. Crocodile
    Crocodile
    Nov 4, 2002
    18,332
    +6,859
    A choice of 2 here from £37.60. I know there are some compatibility issues with 3rd party batteries not supporting all camcorders. I don't know if there are any issues with 3rd party chargers. I suggest that you ensure that you can return anything you buy if it proves to be incompatible.
  4. Mad Matt
    Mad Matt
    Aug 7, 2004
    14
    Reading
    Thank-you!
