SONY or FUJITSU
Discussion in 'Sony TVs Forum' started by johnr2110, Aug 26, 2006.
  1. johnr2110
    johnr2110
    Aug 26, 2006
    2,751
    2
    2
    68
    Eastbourne
    +94
    Hi All
    I'm looking to buy a new TV in the forseeable future & so far undecided between the Sony V-series 40" or the Fujitsu 58 series 42".
    The above TV chosen will be a replacement for our Hitachi 32" crt, so will be used as a general television including DVD & later Sky HD.
    Currently using Sky + & analogue aerial.
    J R
  2. chambeaj
    chambeaj
    Jan 1, 2005
    3,055
    +190
    Fujitsu will provide by far the best picture quality (motion, colours, black levels/shadow detail). However, the Fujitsu is not the quietest of panels (fan noise/buzzing - all down to personal preferance) and it would seem the panel has a problem with image retention.
  3. johnr2110
    johnr2110
    Aug 26, 2006
    2,751
    2
    2
    68
    Eastbourne
    +94
    Hi Chambeaj
    Thanks for the reply are there any plasmas that aren't noisy?
    JR
