Sony Oled frequent IR compensation cycles missing?
talk2r
I've just pulled the trigger on the A8 55 and feeling quite pleased.
While on the Sony website reading info about this tv and oleds, I was looking for info on compensation cycles similar to those 4 hourly ones used by LG, but couln't find any.
However I did find this :
Reduce image retention or non-uniformity on your OLED TV screen​
IMPORTANT: This article applies only to specific products and/or operating systems. Check Applicable Products and Categories for details.
Image retention occurs due to the degradation of screen uniformity as a result of continuous display of the same screen for a certain period of time. In terms of the appearance on the screen, image retention and non-uniformity are similar.
To reduce image retention or non-uniformity, check the following :
  • After using your TV, press the POWERbutton on your TV or the remote control to turn it off.
    • We recommend that you perform this operation every time you use your TV.
    • Leave it off for about six hours or more.
  • Place the TV away from direct sunlight.
    • Sunlight exposure can change the characteristics of your TV screen and may appear as non-uniformit
What are they saying? If I watch it for a few hours I should leave it in standy for 6 hours before next switching on again?
Samsung Micro LED, Mini LED, NEO QLED TVs and More: AVForums Podcast Interview
