Sony - Nwhd1
Discussion in 'Hi-Fi Stereo Systems & Separates' started by satfreek, Oct 19, 2004.
  1. satfreek
    satfreek
    Jul 20, 2003
    5
    4
    Liverpool
    Hello. This is a bit long-winded so bear with me.
    I've just bought myself a Network walkman but the Sonicstage software you get with it doesn't work as I've built my own pc and upgraded the OS of my pc from Windows 2000 to XP Pro. It does state in the manual that it will only work with a factory installed OS. I've installed the software but when I go to import mp3's or copy cd's it just goes off. Is there a way around this. Is there any other software I can use instead of Sonicstage?
    Thanks.
