Sony NW-HD5 wont let me load tracks
Discussion in 'Headphones, Earphones & Portable Music' started by bruceglen, Oct 23, 2005.
  1. bruceglen
    bruceglen
    Just got a sony nw-hd5 followed instructions and everything was fine until i tried to load tracks onto the player.
    When i connect the player it shows up as "Free 18.6Gb ATRAC Audio Device" but when i select the red arrow for transfer it begins transfer and then shows an error report saying "cannot transfer any more tracks. The device/media is full" and displays the tracks i tried to transfer. Instead of Free 18.6GB it now says 0.0kb.
    Now when i turn the player on it says "repairing database" and then "no database found" Help!
  2. drmoze
    drmoze
    Aug 8, 2005
    196
    Try reinitializing it, from the options menu, then conect to your pc.
  3. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    It does sound like re-initialising will help, I assume you can't see the two tracks sony put on the player when it ships can you?
  4. Bertie Wooster
    Bertie Wooster
    I took mine off 'hold' and found it "repairing database". When it finished doing this, the player appears to be blank, with no tracks on it! It was meant to have 1.99Gb left out of 20Gb.
    Then I reconnected the player to my PC to see if it would snap out of this only for SonicStage to spew out some message that the player couldn't be connected to the current version of the program! It suggests that I initiliase the system, i.e. accept that I have lost thousands of tracks.
    As a last resort I have gone to My Computer and trying to scan and repair the drive. The storage space 'pie' shows that only 1.99Gb is free, as per my last connection.
  5. Bertie Wooster
    Bertie Wooster
    ..and dare I ask, why is "repairing database" not in the manual?
