Sony NW-HD5 Volume Info
Discussion in 'Headphones, Earphones & Portable Music' started by Jonny5Alive, May 11, 2005.
  1. Jonny5Alive
    Jonny5Alive
    I mailed Sony asking if the Volume on the NW-HD5 is limited like the NW-HD3 and if it could be disabled, this is the response I got....
    The NWHD5, like he NWHD3, uses the AVLS system to limit he volume levels of the unit, this can be turned off in the menu settings for the unit. It also has a system which limits the maximum power output in order to maintain a balance between battery life and power output, this facility can not be turned off.
  2. stiffneck0
    stiffneck0
    Hi Guys! :thumbsup:
    Received my NW HD5 today from Sony Style. Working perfect!
    Have also set the Sound Limiter (also known as Sound Pressure or SP for
    short) to OFF. The procedure for doing this is the same as the one detailed
    on another thread located on this site for the NW HD3!! Hope you find this
    info useful....ENJOY YOUR HD 5!!! :clap:
    Stiffneck0
    UK
  3. Alcahest
    Alcahest
    Apr 10, 2005
    52
    Hey Stiffneck, could you check on your HD5 to see where it's built?
    I'm trying to find out if all models are made in Malaysia or if some are built in Japan..
    LAter,
    Alcahest
  4. Phil K
    Phil K
    Mar 6, 2005
    68
    9
    Stiffneck - does it do proper bookmarks ? (Dying to find out, as I am itching to get my hands on the 30gb one ! (The nw-hd5h)
  5. stiffneck0
    stiffneck0
    HI,
    CHECKED -- MADE IN MALAYSIA
  6. stiffneck0
    stiffneck0
    HI - SORRY HAVE NOT TRIED BOOKMARKS AS I GENERALLY LISTEN TO
    ALBUMS AT A STRETCH....
  7. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    mines from maylasia.
  8. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Same here.
