Sony NW HD5 connection to HiFi and car?
Discussion in 'Headphones, Earphones & Portable Music' started by Catastrophe, Jun 9, 2005.
  1. Catastrophe
    Catastrophe
    Apr 20, 2005
    43
    sorry if the question is noobish.....but what cables do u need and where u connect to on HiFi or car?
  2. Hrochnick
    Hrochnick
    Apr 28, 2005
    369
    Brno
    +9
    There seem to be three possible solution, the first is that some modern cars have a direct input where you plug your player straight in via a 3.5mm jack - this is obviously the best sounding and easiest solution but not many cars have it. The other two options will not sound as good but you're in a car travelling at speed with all the noice that that entails so how good can it be? I wouldn't worry about it, personnaly. The second method is via a tape connector - you plug your player into a special tape (which are cheap and easily available) which goes into the tape deck but if you only have a cd player in the car that method is no good for you. I use the third method which is by fm transmitter, these are harder to come by because, I think, they are actually illegal in the UK (though I can't think why). This is the method I use and it works fine for me. The only problem being the difficulty of finding a clear frequency range in London - not easy - and if on a long journey I find I have to re-tune to periodically to maintain a clear signal. Works well enough for me and I like it.
  3. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
    Cable for HIFI connection.
    http://www.audiovisualonline.co.uk/...gold-pga3405-5m-3.5mm-jack-2-rca/display.html
    Excellent cable for good sound quality (I have one myself).
    Car FM Transmitter
    http://www.amazon.com/exec/obidos/tg/detail/-/B0001F22PA/104-5679802-3879157?v=glance
    I bought one of these on EBay from a guy in the states.
    Technically you are not supposed to use them in the UK as (believe it or not) you can be prosecuted as a pirate radio station even though it is unlikey people would even pick up the broadcast in the next car in a traffic jam.
    Good unit though.
    A better solution for the car, if you can find a head unit with a jack socket on the front panel, would be a direct cable to cable connection for the best sound possible.
