Sony NW HD3 - settings problem
Discussion in 'Headphones, Earphones & Portable Music' started by fbloke, Jun 28, 2005.
  1. fbloke
    fbloke
    I've just bought one of these marvellous MP3 player thingies I've heard so much about but Im a bit frustrated by a problem I've encountered.
    Whever I change a setting - eg beep to off - it reverts to the original setting next time I turn it on.
    Similar things such as backlight and reversing the colour scheme etc do the same.
    Am i mad or just plain stupid?
    How can I make my preferences permanent?
    Andy
  2. rigger123
    rigger123
    Feb 1, 2005
    77
    Norwich
    Are you turning the player off by holding down the menu button or are you sliding the switch at the bottom? I think if your sliding the switch the circuitry is actually disconected from the battery. Try just using the menu button to turn the player off and see if that works. If this does not solve the problem then i am as stumped as you.
    (note: in the manual it says that your supposed to slide the switch when the player will not be used for 3 months to stop degredation of the battery)
  3. fbloke
    fbloke
    Thanks for the idea but thats not doing it.
    I will keep trying other things though.
  4. fbloke
    fbloke
    Just to prove i am an idiot, it did work.
    Andy
  5. kingh32
    kingh32
    Mar 6, 2005
    10
    So u mean that the battery off switch shouldn't be used for short term purposes?
  6. rigger123
    rigger123
    Feb 1, 2005
    77
    Norwich
    fbloke, no problem mate! :clap:
    Kingh32, i'm not too sure, it depends how you interperet the manual i suppose. but i personally don't use the battery switch (cos its too small and fiddly :rolleyes: ) unless of course im not using the player for a few months!
  7. kingh32
    kingh32
    Mar 6, 2005
    10
    Ok, I use it overnight and its been fine for me, keeps the battery going.
    Cheers anyway
  8. Chox1988
    Chox1988
    Mar 30, 2005
    16,824
    basingstoke
    +9,280
    The battery off switch is designed if you are not using the player for months at a time, so the battery doesnt drain or something (says in the manual). The menu switch is how it's meant to be turned off generally.
