Sony NW-HD3 - Removing the ferrite rings.
Discussion in 'Headphones, Earphones & Portable Music' started by webchimp, Mar 25, 2005.
  1. webchimp
    webchimp
    I have a Sony NW-HD3, I was wondering if removing the ferrite rings from the "walkman" end of the power and USB cables would cause any problems?
  2. watchinthewheel
    watchinthewheel
    what exactly do those thing do? i have always wondered, they dont seem to actualy be attached to the wire.
  3. Hasselhoffia
    Hasselhoffia
    Probably not. Usually they are used to reduce interference on the wire but I'm betting that Sony are overengineering and you can get away without them. Wondering why you need to remove them though?
  4. webchimp
    webchimp
    Well, I've removed them and so far, no ill effects.
    They are used to reduce interference on unsheilded cables, something to do with modifying inductance, but I'm no physicist and couldn't explain how it works.
    The only reason I wanted to remove them is that they are quite bulky and heavy. The connector is otherwise quite compact and lightweight and it's much neater without them. I have enough cable clutter on my desk as it is. :)
  5. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Sorry, what are the ferrite rings?
  6. Hasselhoffia
    Hasselhoffia
    Well to be technically correct, we are talking about ferrite filters. They are the black plastic tubes clamped over the power wire, with the wire looped around it several times. In the plastic tubes is a magnetic cylinder that helps reduce interference.
