Sony NW-HD3: Playlist Thing!
Discussion in 'Headphones, Earphones & Portable Music' started by humbled34, Aug 15, 2005.
  1. humbled34
    humbled34
    I bought my walkman 2 days ago, loved it so much. I already installed 15GB's of music. So cute.
    My question is about playlist. There is no playlist in this walkman (i guess "groups" stand for playlist. How can i make a playlist that's already in my walkman. I tried this on Sonic Stage v3.1, but the software transfered the songs on the playlist, which were already transfered before. Any help would be appreciated....
  2. Gemini-Phoenix
    Gemini-Phoenix
    Jun 23, 2005
    391
    Ipswich
    +13
    There is a "Bookmark" function, but I will be damned if I know how to figure it out...
    How the hell do I "Bookmark" my favourite tracks on this thing?
  3. *baggie*
    *baggie*
    Apr 13, 2005
    23
    Playlists on the HD3 dont work properly. They are OK when you view in the Group mode but in Album/Artist view the playlist tracks will be duplicated. A successful work-around is described in the following thread
    http://www.avforums.com/forums/showthread.php?t=226986
  4. *baggie*
    *baggie*
    Apr 13, 2005
    23
    Bookmarks - press wheel up to add currently playing song to bookmarks. Repeat to remove songs from bookmarks. Max of 100 bookmarks on hd3.
  5. lchiu7
    lchiu7
    I was able to achieve a sort of playlist function using Groups. For example I have a bunch of songs which might be categorised Broadway show tunes (but scattered across a number of Groups/Albums).
    I fired up SS and viewed the songs on the HD-3. It shows all the groups of songs I had. I then clicked the create group icon at the bottom of the list (called it Broadway) and then dragged songs from the various relevant groups to that folder.
    When I look at groups now on the HD-3 I can see a group called Broadway with the songs I dragged there. But also if I look at the albums from where the songs came they are still also. I don't think SS created copies - it just created pointers
    Anyway worth a try
