Sony NW HD3 is sonicstage the only way?
Discussion in 'Headphones, Earphones & Portable Music' started by dogslikeyou, Jan 31, 2005.
  1. dogslikeyou
    dogslikeyou
    I bought my hd3 about three weeks ago, after reading a review that said that you did not have to use sonic stage to transfer music to the hd3 does any body know of any software? this would be a great help because as most of us know SS suffers all sorts of tech and bug probs. i have look at real player but it was no good
  2. Hasselhoffia
    Hasselhoffia
    Yeah, hold tight for Real to update their plugin to support the NW-HD's. Can't be far away.
  3. dogslikeyou
    dogslikeyou
    Thanks for that Reply
    But i am not holding my breath for Real's update on the driver the hd1 has been out a fair while now and they still have not got one for that!
    Do you know of any other software that might bring out a driver for the hd3?
  4. cashback
    cashback
    Feb 2, 2005
    60
    +3
    not true you can now put music on your nwhd1/3 using windows media player 10 series
    just connect your device and click sync hope i helped
  5. aljanomac
    aljanomac
    Jan 24, 2005
    40
    Cashback, how do you find it using Windows Media 10? - Also, does it support Atrac as well as mp3?
    Reviews on a postcard please... :)
  6. cashback
    cashback
    Feb 2, 2005
    60
    +3
    it is alot easier than using sonicstage but sadly it does not support atrac3plus :(
  7. cashback
    cashback
    Feb 2, 2005
    60
    +3
    oops soz bout size :spam:
  8. mg-paul
    mg-paul
    Jan 26, 2005
    181
    28
    Andover
    +25
    also doesn't seem to work with WMA files :(
  9. Doomke2k4
    Doomke2k4
    the player isnt playing wma...
  10. shiveringgoat
    shiveringgoat
  11. watchinthewheel
    watchinthewheel
    im prepared to be mocked for this but how do i download sonic stage 3 i cant find a link anywhere.
    has anyone tried it, is it much better than 2.3?
  12. Spacecowboy
    Spacecowboy
    Theres a link in one of the other threads i think.
    SS3 so far is only for the US, i downloaded and installed it yesterday, but was a wee bit miffed that i had to re-intitialise my HD3, for it to work, no matter i just left it to re-transfer my tracks overnight. Actually it wasnt so bad i only had about 3gb of music so far.
    Another thing is it wouldn't let me regiter with Connect, cause i'm in the UK.
    1 other thing i noticed, is that it still doesn't seem to be able to creat 'proper' playlists. It does let you create so called playlist, but ends up copying the same tracks that are already on you HD3 again, therefore you have 2 copies of alot of tracks :(
  13. washout
    washout
    u were suppose to register in 2.3 BEFORE u upgrade, otehrwise u are screwed
  14. watchinthewheel
    watchinthewheel
    dammit i didnt know i would have to reset my hd3, its taken me ages to get it how i want it using ss2.3 that @&£*% piece of *%&£@ god i hate it so much!
    looks like ill have to go back to it now though
  15. Spacecowboy
    Spacecowboy
    I think i've registered...... i regstered with something on cennect when i had 2.3, the form only asked for my name, address, email etc but i thought they asked for your HD3 serial no. as well? I got an email thru, i'll have a read thru it.
  16. nimrodity
    nimrodity
    how can i transfer mp3 to my upgraded hd1 with the wmp10,when i sync the hd1 finds no songs.And does anybody know why all my songs on my hd1 are .oma although i tranfer them a .mp3 and there is no conversion.(with Sonicstage and the vaio tool).Another problem is every few tracks sometimes every track need a long time to tranfer(3 to 10 minutes for 1 album)and sometimes not(about 1minutes per album)but more often it needs very long,but why?
  17. washout
    washout
    if u did register then good, go to music sourse, in sonicstage, click connect music shop, then go to ur accoount and enter details, u need ur login password and email address u registered with. now in ur account it will tell u the device serial number and the pc details. now dock the hd3 or hd1 go to transfer button top right click on atrac audio device, go to the bottom right and ul see a button ,click it and click authorise and the device should then work for u.
  18. washout
    washout
    in fact it is easy to know if u have registered, when u try to register a new account in the login screen if u have previously registered an account then it will say an account has already been registered on this pc u can only have 1 account.
    so its easy to know if u have registered or not.
  19. Spacecowboy
    Spacecowboy
    I tried to login but got this message:
    "It appears that your computer is currently accessing Connect from outside the United States. Due to licensing restrictions, music on Connect is not available for download from outside the United States." :(
    I guess i'll just have to wait till SS 3.0 is released for Europe.
  20. washout
    washout
    that is very unusual, i am in ireland (southern) and it works 100%. in fact i have just purchased 4 tracks from SS3 connect usa store. mayb sonys uk connect shop means that sony dont want anyone using the cheaper usa site. i suppose with ireland it wouldnt matter which we used as there is no connect ireland store.
    so basically moral of the story is stick to SS2.3 until 3.0 comes out for europe. :lesson:
    it mayb possible u already reged with sonys uk connect store which would mean the usa store is rejecting u. sonys support isnt too good so who knows, sorry anyway
  21. caz1979
    caz1979
    Feb 23, 2005
    61
    As I posted in another thread I too was using 2.3 and upgraded to 3. I had already registered with Connect and purchased a track and although I could see the Connect homepage I couldn't listen to any preview tracks. I clicked some link or other to test the connection and got the 'clear off you're not from the US' message.
