Sony NW-HD3 gig recording??
Discussion in 'Headphones, Earphones & Portable Music' started by jamie60509, Mar 23, 2005.
  1. jamie60509
    jamie60509
    I currently use a MD recorder to record live gigs etc. and was wondering if I'd be able to do this on the NW-HD3 if I was to get one?
    Also, will the remote that I use with my Sony MD be compatable with the NW-HD3?
    Thanks in advance!!
    Jamie
  2. webchimp
    webchimp
    I don't know about the remote, but you can't record with the NW-HD3, there is no line in or microphone connections. The only way to access the device is with a PC using the joint USB-power adapter.
  3. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Yes, Sony MD remotes will work with the HD3.
  4. Hasselhoffia
    Hasselhoffia
    ... as long as it's not truely ancient... :)
  5. dragthewaters
    dragthewaters
    i've got the remote for my sony md, i think its the mzn 710. the play, stop and track skip buttons work but the screen and the sound buttons dont with my hd3
