Sony NW-HD3 Copy Protected CD's
Discussion in 'Headphones, Earphones & Portable Music' started by Ravi V, Jun 15, 2005.
  1. Ravi V
    Ravi V
    Just bought this MP3 from Sony but unfortunately most of my CD's are copy protected!
    Does anyone know if or how these can be transferred onto Sonic Stage and then onto the actually MP3?
    Cheers.
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,452
    +6,230
    Have you tried putting them in CD drive? I have several "copy protected" but all I did was close the media player that loads with the CD (you know, on CD case it says you can't play with normal media players e.g iTunes, windows media player etc, only on one they provide on CD to stop copying),
    then on Sonic Stage or iTunes, I instruct it to look in CD drive. Hey presto I can copy the CD. Weird that the "copy protection" doesn't work. Or in my experience anyway.
  3. njiri
    njiri
    Oct 26, 2002
    149
    19
    UK
    Rip the CD using windows media player (if you use windows XP)
    Then import the files into sonicstage.
  4. FifeFlyer
    FifeFlyer
    Feb 12, 2005
    Fife, Scotland
    Using Slysofts AnyDVD works (it works for CD's as well as DVD's). If SonicStage can't import the tracks because the CD is copyprotected then running AnyDVD removes the CD copyprotection and lets you import it. Try the 21 day free trial and see if it helps. Here is the link http://www.slysoft.com/en/anydvd.html
    Hope this helps solve your problem.
