W
watchinthewheel
i have a hd3 and have tried expensive earphones, the supplied earphones and even pc speakers and not found any hiss at all even at high volumes.
watchinthewheel said:i have a hd3 and have tried expensive earphones, the supplied earphones and even pc speakers and not found any hiss at all even at high volumes.
watchinthewheel said:just tried that and couldnt hear anything. just a normal background noise, and if its THAT quiet why does it matter anyway? if it goes away when you play anything at a regular voulme just dont turn the sound down to listen to it.
washout said:u are correct, it is irrelevent basically. as the volume is slowly turned up the background noise remains as the music drowns it out. but bottom line is its normal and doesnt matter anyway.
washout said:i bought 2 hd1s and have concluded all hd1/hd3 hiss at low volumes. to check lower the volume to zero with a track playing and u will hear a hiss for sure even on the original earphones. ALL HD1S HISS. make no mistake, the fact that the music drowns out this hiss is fine, but they ALL hiss.
mariahcarey said:Got my HD-HW3 today from amazon and absolutely NO HISS watsover! The unit is awesome, can i say DEATH TO IPOD!
