Sony NW-E507 Group mode
Discussion in 'Headphones, Earphones & Portable Music' started by Zevs, Jul 6, 2005.
  1. Zevs
    Zevs
    Hi!
    Just bought at Sony NW-E507 and is very happy about the looks, the size, the sound quality and the FM radio. The SonicStage software is not the best one, but it works (is the transfer really USB2 though, seems a bit slow....?) But my question is about the Group mode. If you pull the "cork" of the "bottle" all the way up you are supposed to be able to rapidly switch between albums by just turning the top part. On mine I get a double beep and then nothing more happens. Anyone have any idea of what I'm doing wrong or what the player is doing wrong....
    Grateful for response and help!
    Zevs
  2. rojack
    rojack
    hi - i'm an equally satisfied NW-E407 owner...
    before you pull 'the "cork" of the "bottle" all the way up'
    you must select either: Artist - all artists, Album - all albums, Group -all groups... then press play, and do your thang! for this function to work :)
