Sony Multi PIN old 8 pin DIN
Discussion in 'Cables & Switches' started by Gavin Oliver, Oct 27, 2004.
  1. Gavin Oliver
    Gavin Oliver
    Hi all,
    Newbie building my first home theatre and would like to connect this to an old Sony with a 8 pin din connector.
    The output from my video card is DVI i and s video.
    Question is it possibe to connect the two?
    If so which is best and what cable and pinouts do I use?
