Sony Multi-changer problems
Discussion in 'Portable Disc & Media Players & Recorders' started by Mafty, Jun 25, 2003.
  1. Mafty
    Mafty
    Aug 27, 2000
    11
    Weston Super Mare, Somerset, UK
    I have a problem with my Sony head-unit/changer combination.
    When you are playing a CD, the unit suddenly stops playing the disc, bleeps, and flashes 'RESET' on the screen. It only does this in CD mode - radio and tape are fine - which leads me to believe it's a problem with the changer rather than the head unit.
    The head unit is a XR-C450RDS.
    The changer is a CDX-70.
    Has anyone come across this problem before, and if so, is there a fix, or is my changer FUBAR?:confused:
  2. Mafty
    Mafty
    Aug 27, 2000
    11
    Oh yeah, i forgot. It also comes on in 'Phone Mute' mode when you power up. I've checked that the mute wire is not shorting to anything.
    Help!!!
