Sony MDR-EX71 Earphones
Discussion in 'Headphones, Earphones & Portable Music' started by RichardB, Nov 30, 2004.
  1. RichardB
    RichardB
    Sep 28, 2004
    34
    Hi, just wondering if anyone out there has a pair of these can can tell me whether the cables to each earphone are of different lengths or not (so you can hang 'em over your shoulder with the earphones out your lugs, if you know what I mean) :)
    Thanks!
  2. rOAdeh
    rOAdeh
    Jan 24, 2003
    602
    Winchester
    +5
    hi Richard,
    yes they are. Mine came in a 2 part cable, so if you have a remote already you don't need 6m of wire and the wire to the left ear is significantly shorter than the right one so you can wear it to one side.
  3. RichardB
    RichardB
    Sep 28, 2004
    34
    Cool, thankd rOAdeh - got a remote, so the short cable is appealing too.
  4. CJROSS
    CJROSS
    Nov 16, 2000
    5,070
    +343
    Great sounding phones too Richard.
  5. GizmoStu
    GizmoStu
    Dec 1, 2004
    38
    London
    +4
    I own a pair of these and they really do the job well. Great for commuting as they fit right in the ear. This means that along with having a noise cancelling effect you can have them up a little bit louder than normal without disturbing your fellow passengers.
