SONY MC55ELK & HD5
Discussion in 'Headphones, Earphones & Portable Music' started by stylez_paniro, Aug 10, 2005.
  1. stylez_paniro
    stylez_paniro
    i have purchased a MC55ELK which is the top of the range remote sony have made...even better than the MC40ELK....however it doesnt work on my HD5!! i have a white one with white EX71SL headfones n it looks so good....too bad it doesnt work...
    does this mean no remotes with screens are compatiable with the HD5? it worked on a HD3...
    the screen does not work at all however the volume and track change does...
    plz help!
  2. jceric
    jceric
  3. stylez_paniro
    stylez_paniro
    my friend has a mc40elk with his minidisc player n it works PERFECT with my hd5...so im gonna try get that one
  4. sxc
    sxc
    Jun 5, 2005
    56
    +4
    Not sure why you say the 55ELK is the most advanced remote and is better than 40ELK. The 40ELK has the jog dial that makes getting through tons of music so much easier than any other remote.
  5. booges
    booges
    Dude you are sooooo wrong..
    I have the mc40elk and it works fine. EVERY FEATURE WORKS..
    Do your homework man
