Sony losing colour - help please
Discussion in 'General TV Discussions Forum' started by gmk, Feb 23, 2005.
  1. gmk
    gmk
    Hello
    The picture on my TV changes colour intensity to less colour for no apparent reason. After a couple of minutes it goes back to normal intensity.
    The side of the TV is about 2feet from a radiator. The centre speaker for a Phillips home cinema system sits on top of the TV but the Phillips amp is switched off (but plugged). The woofer is about 2feet away. If any of that could be a problem - why?
    Thanks.
    The set is a Sony KV-28FX20U
  2. sdk
    sdk
    It might be the radiator
  3. JayCee
    JayCee
    Jan 20, 2004
    24,002
    Lanarkshire
    +2,618
    If your set is under warranty get it checked by an engineer.
    The radiator and speaker (if it was unshielded) would not cause these symptoms (loss of colour) but purity errors (patches of incorrect colour).
    To satisy yourself why not remove the speaker and move the Tv further from the radiator temporarily?
