Sony - Light line on right
Discussion in 'General TV Discussions Forum' started by dolph, Mar 17, 2003.
  1. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Help... I have just noticed that on my KV28FX66 a light "line" has appeared on the bottom right hand side of the screen.
    This wasn't there when I first got it (only two weeks old).
    The "line" is about half an inch wide at the bottom of the screen, tapering off to nothing from half way up - it's curved.
    What is this??? I have just been watching Jason Bourne, could it be the speakers from my DAV?
    I need help urgently please....
    What can I do?
  2. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Just thinking about this it's possible the line has been there since I first turned it on - has anyone else ever noticed somethink like this on a Sony?
  3. MattDX
    MattDX
    Possibly the speakers try moving them futher apart but they are probabaly shielded so don't get your hopes up. It could be that you have the brightness up too high. Try lowering that a bit and see if it helps.
  4. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Speakers are definitely shielded (well I say definite as they say they are on the labels, but you never know!!;) ) Will look into brightness tonight but how would one area be affected differently to the rest, it is only a very small part of the screen that is affected in the bottom corner?
  5. MattDX
    MattDX
    Having tuned my TV recently (32FX66) with a special test pattern DVD one of the things it pointed out is that if you have the brightness up too high a light square can sometimes be seen and I think that was in the bottom right side.
  6. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Special test pattern DVD? Sounds interesting - what's it called?
  7. MattDX
    MattDX
    Cinema Essentials - it's a very good setup disc.
  8. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Where can I get that from?
    Does it do Audio as well (may seem like as stupid question but I have to ask!!)
  9. Lpool
    Lpool
    Yes it's there on my SonyFS76..
  10. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Do you have speakers near your TV or am I barking up the wrong tree?
  11. Lpool
    Lpool
    Well..the speakers can do that to a tv..mine does..but now I have moved them a little bit further away and the light parts in both corner dissapeared..but the light part on the right side of my telly is still there..and that is a fault...
  12. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Yup, mucked about with the brightness yesterday and that didn't do anything.
    However have realised that the line isn't that bad, I only really noticed it when I was taking a dvd out of my system so I was REALLY close to the TV. Although I can see it from where I sit it's right at the edge of my field of vision anyway so it's not too much of a problem.
    Would be interesting to know if there's anything you can do in the service menu to sort this out (not that I'm going to go muddling around with it to find it!!;) )
  13. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
