sony leads
Discussion in 'LCD & LED LCD TVs' started by briane, Jan 1, 2005.
  1. briane
    briane
    Hi, help needed, in the process of buying a sonyKLV-L32M1 but unsure about salesmans advise to buy extra (better) quality leads and surge protection box. About another £400/£500 pounds worthin total.Is this necessary or just a good deal for comet!
  2. Yaka
    Yaka
    Dec 20, 2000
    1,682
    2
    63
    +115
    urm £400 worth of Leads?? i think you should buy from else where. decent Belkin surge protectors cost around £40 come with life time gurante.
    Scart/component/svhs/dvi leads for quality ones cost around £40 onwards form reputable makes like QED, Monster Chord etc. i think the most your looking for is a couple of scarts, compnent out cable should only come to around £150 unless your living room is short on wall sockets.
    just click on the banner adverts on this sites you'll prolly find a cheaper deal.
