Sony LCD KLV-32M1 has hdmi - Version in currys does not!!
Discussion in 'Sony TVs Forum' started by spergabite, Oct 1, 2004.
  1. spergabite
    spergabite
    Jul 23, 2004
    46
    I was looking on the Sony us website and noticed the spec of the 32" KLV-32M1 has an hdmi input - great! However it would appear that the uk version does not. If you do a search on google for this model it is available in the uk with hdmi(according to the resllers website which may be wrong) i thought the picture quality on this lcd was excellent, through component(i actually saw the tv connected in a sony centre with component!, this is a first for me)
    So my question, does anyone know if this set actually has hdmi? or is the resllers website wrong, if it does have hdmi it is superb value as its one of theonly 32" lcd panels i know of with 16:9 screen ratio and i will be seriously thinking of getting it instead of the samsung 32"
  2. McGraw
    McGraw
    Sep 29, 2004
    312
    +11
    I have examined 3 of these in UK shops including Sony centres.
    None of them had HDMI input.
  3. McGraw
    McGraw
    Sep 29, 2004
    312
    +11
    Actually, I'm thinking of buying one of these.
    Would it be worth buying the US version if it has HDMI?
  4. spergabite
    spergabite
    Jul 23, 2004
    46
    i just had another look at the website and they mention an ntsc tuner, so i think they have just copied and pasted from a us website.. its also worth mentioning that if its a us model it will have no rgb, not that it bothers me as i will just use hdmi component and s-video...
