Sony Lcd Anybody?
Discussion in 'Sony TVs Forum' started by matthewjohnson, Oct 24, 2005.
  1. matthewjohnson
    matthewjohnson
    I am looking at the sony bravia range of tvs, and i am thinking about buying the KDLV32A12. i am nervous because it is a lot of cash, and although the hd demo i have seen on the tv is fantastic, the standard picture quality isnt that great. can anyone convince me to buy this tv, or indeed recommend an alternative.
    thanks very much
  2. mistrip
    mistrip
    Aug 16, 2002
    319
    UK
    +12
    There's a long thread about this range of TVs here:
    http://www.avforums.com/forums/showthread.php?t=239231
    Some people love it, some don't. I wasn't impressed with it at first but that was with a poor freeview signal, that makes all tvs look pretty bad. Having seen it with a decent feed though it looks better than i'd first thought so i will probably get one soon.
  3. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    Depending on what price you've seen it for, same money can buy you a 37" JVC DS6 or Sharp 37" GA6 or GD7 for not much more.
    Equally, should you hold off until next Feb/Mar, there'll be Benq's 37" full HD resolution TV by then, for similar money. 1920x1080 as opposed to 1366x768.
    Also gives you a bit more time to save some more towards it or any of the larger panels coming out.
  4. Rob Sheep
    Rob Sheep
    Aug 17, 2003
    155
    16
    Worcester
    Mr Johnson, The 'S' series has a better picture, I think that the WEGA Engine is what the fault is with the V series. However, better screens are about..
