SONY KV36FS70 PROBLEM
Discussion in 'General TV Discussions Forum' started by Cinders, Jul 11, 2001.
  1. Cinders
    Cinders
    I was wondering if anyone could advise...
    My tv is only 1 month old and in the top left hand corner it has developed a green tinge when on a white background.
    It looks like a magnet has been placed on it. Now I live by myself and I know for sure that nothing has been put ontop of the tv, nothing.
    What can I do about this tinge? I mean it's only small, but I can see it if I look for it, it's definately there and I don't think it should be on a £2K tv set.
    Do I live with it, or will Sony sort it out for me under warranty?
    Any suggestiosn much appreciated!
    thanks, matt.
  2. ScottGreatorex
    ScottGreatorex
    Speak to the place you brought it from, they should send out an engineer to fix it for you, under warranty. its a simple process.
    Scott
  3. wirez
    wirez
    You've probably got it close to a metal radiator or something. Reposition it at the other end of the room, and turn the set on and off with the on switch for about two weeks instead of using standby. The automatic degausser will probably take care of it. If not an engineer will degauss it for you, its a simple process.
