Sony KV32LS60 or Sony KV32FX66
Discussion in 'TVs' started by Rookies, Jan 13, 2003.
  1. Rookies
    Rookies
    Jan 4, 2003
    4,900
    103
    +345
    right I was going to go for a FQ80 but it was alot of money i though even though it is a top notch tv. Things I dont need on it too like Memory stick reader which put price up
    Any way as the subject i am now thinking between those two. I seem to like the look of the FX66 more than the LS60. But I would like to know which one should show better picture clear flicker free etc etc. Sounds is not a issue.
    Any help here ???
  2. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    I have the 32fx66 and really like it the picture is 1st class and I see no flickering, can't speak for the ls60 as i have never looked at one but I don't think I have seen a really bad report on either tv.Best bet is to go into a shop with a dvd and demo both and see which you prefer. I didn't look at ls60 as IMO I thought the styling was a little dated so i opted for the fx66 it was nothing to do with spec
    Good luck deciding!:eek:
  3. Rookies
    Rookies
    Jan 4, 2003
    4,900
    103
    +345
    I agree I like the look of the FX66 more. But i just wonder which is better at performance.
    Does the FX66 have BBS?
  4. Rookies
    Rookies
    Jan 4, 2003
    4,900
    103
    +345
    Also I believe neither of these tv well let me select a 50hz or 100 hz as I beleive the FQ80 have the option so i can select 50 hz if sports does not appear correctly on 100 hz is thist correct
  5. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    Not sure what BBS is? and you are right the fx66 is 100%-100hz no mode for adjustment but the sport is fine I watch most football that is televised and it really is a great picture
  6. Rookies
    Rookies
    Jan 4, 2003
    4,900
    103
    +345
    Hi that is kewl to hear sports such as football is good on this set
    I meant BBE not BBS sorry. It to do with the sounds
  7. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    still not sure what BBE is lol!.... Sound is good tho' plenty of volume and a nice balanced output with a few different settings ......I think you will be pleased if you go for it check out some of the other threads on here most people love the set:kisses:
  8. w3dal
    w3dal
    Aug 4, 2002
    4,919
    Chelmsford, Essex
    +543
    The FX66 does have BBE and Virtual Dolby Surround.
    Dal
