Quantcast
SONY KV32LS36 menu
mk
Does anyone know how to change the 'sharpness' option in the picture menu ?> It is greyed out on my set so not selectable.
Other options like brightness, contract etc can be changed in the personal option but not sharpness.
Any help appreciated.
mk
Yes RGB - SKY though scart lead into AV1 16:9 ratio
P
Paul Atreides
You cannot adjust Sharpness on RGB video, it is enabled for all the other inputs however.
nd4spd
...But you can do the following: change the RGB source in whatever it let you adjust the sharpness, adjust the sharpness (more or less depending on what you want to achieve) and finally get back to your RGB source and see the efect of the sharpness even if it doesn't let you to adjust it. You may have to go back and forth a little for proper adjustment of sharpness.
Vali
HowieC
The best procedure is..
Select a channel on the analogue tuner,
Go into menu and select sharpness,
With sharpness adjustment still on screen change to RGB source,
The sharpness adjustment is now available for your RGB source.
mk
Sorted - adjust in analogue source and change to RGB
Thanks to all who replied
nd4spd
With my set (KV32FX68) your procedure does not work as the sharpness adjustment becomes grey when I change from analog to RGB. That's why I gave my above advice. I must admit it is much harder to adjust sharpness in my way because one cannot see the imediat efect of sharpness on the image.
HowieC
If you scroll down to sharpness and then press OK do you get a sharpness bar at the bottom of the screen? And if so, if you then press the source select to go to your RGB source what happens to it?
(I didn't think the fx66/fq70 & fx68 menus varied much)
nd4spd
I don't know, maybe I'm missing something here but the only adjustable bottom bar is volume. As I said if I have an analogue source and enter in the picture submenu, select the sharpness and go to its adjustable slider, changing to a RGB source it makes this slider grey which means unadjustable even if the sharpness filter is aplied to the RGB source with whatever value was set on the analogue source.
HowieC
Thanks for that, it appears that the trick that works for the fx66/fq70 range doesn't work for the fx68.
Similar threads
