Sony KV32LS35/DAVS500
Discussion in 'Blu-ray & DVD Players & Recorders' started by ma6235, Nov 5, 2001.
  1. ma6235
    ma6235
    Hi Everyone,
    Thinking about entering the world of home cinema. After searching these forums I wondered if the above package would make sense. I would not be looking to upgrade for sometime. I notice that the TV has only two SCART connectors. How would I connect up a SKY digibox and VCR to get the best performance from the system ? (I'm still confused about RGB's etc) If my budget allows I might replace my old VCR. any suggestions ? Is the DVD multiregion or can it be hacked ?
    Any further comments or suggestions would be appreciated.
    Thanks.
    Mike.
  2. S
    S
    Jul 9, 2001
    237
    +8
    [ I did reply to this earlier but it seems to have disappeared... ]
    The DAVS500 can be made multi-region but it requires a hardware mod. Reckon on £30-£50 above the R2 price.
    One of the drawbacks of the S500 is that it only supports S-video and composite video; there's no RGB output.
    On the plus side, this simplifies your connection options as only one SCART (usually AV2) will support S-video.
    I would connect them as follows:
    DVD->AV2
    VCR->SAT
    SAT->AV1
