Sony KV32FX68 in 4:3 mode
Discussion in 'General TV Discussions Forum' started by Matt Hamblin, Jan 14, 2004.
  1. Matt Hamblin
    Matt Hamblin
    Just bought a 32FX68 and I've noticed in 4:3 mode that the picture is noticeably narrower at the bottom than the top. This occurs with both TV broadcasts and 4:3 DVDs. I rang the supplier and he told me that geometry problems like this were very common and that he did not consider it a fault. Is this true and, if so, am I likely to see any improvement with a substitute set. Is it common with other manufacturers? I'm planning to look at another Sony 32KC68 in another shop to see if it suffers the same problem.
    The other solution is to use the "Smart" picture mode for 4:3 pictures which expands it to the full wide screen format. However, this mode expands the edges of the picture and, in my opinion, looks unnatural.
    Any advice would be gratefully received!
  2. pward
    pward
    Dec 28, 2003
    42
    Most CRT's do suffer from imperfect geometry to a greater or lesser extent. Different samples of the same model can also vary significantly.
    It can be adjusted using a hidden 'Service Menu', designed to be used by experienced TV engineers only. Perhaps you could contact your supplier and ask them to send an engineer to adjust the geometry as whilst they may not consider it a fault, you certainly do!
    Paul
