Sony KV32FX66TNS.U
Discussion in 'General TV Discussions Forum' started by marcusf, Jul 22, 2002.
  1. marcusf
    marcusf
    :confused:
    I am thinking of buying a Sony KX32FX66TNS.U as my first widescreen TV, together with a Sony DAV-S500 and SLVSE820 VCR. I think this should give me a good starter system and also change from £1,700.
    Does anybody have any experience or comments, good or bad on any of the above.
    Also, how does this (or any other) TV provide pictiure-in-picture with only one tuner & what is Dynamic picture-in-picture??
    [email protected]
  2. dac
    dac
    Jul 6, 2002
    439
    London
    +16
    marcus,
    i was in a very similar position to you.
    eventually got convinced into going the separates route.
    also, the budget is approx £2000, but you can mix and match to get what you want for £1700.
    please read this thread here to find out what i will be buying instead.
    cheers,
    dac
  3. marcusf
    marcusf
    Hi dac,
    Thanks for your reply. I have read through your other 32dx100 v 32fx66 thread and got loads of useful information from it.
    Just when I thought I have anice little package in my mind (32fx66 & DAV-S500), you go and throw me into turmoil again. Not being the most confident person when it comes to new technology, I thought an all-in-one system suited me fine, but maybe I should look at seperates instead. Aarrrgghhh!!!
    Do you think a complete novice like me would have trouble putting a seperates system together? The thing I liked about the DAV-S500/600 package was that it sounded pretty easy to set up - a huge bonus for me (and my wife liked the speakers on the DAV-S600, which believe me makes a difference!!!).
    Also, I hadn't thought much about having a built in digital decoder. At the moment I have Sky Digital via sattelite anyway and plan to keep it, so I suppose I don't need to worry about that too much (do I?). Let me know if you hear/read of any 32fx66 reviews - I will keep my eye out too.
  4. rowbos
    rowbos
    Jul 9, 2002
    290
    Minehead, UK
    +3
    Hi Markus,
    These are exactly the same kind of issues going through my mind at the moment also!
    I am considering the 32fx66 together with possibly the new DAV-S550, which adds more power and a slimmer unit together with DPL-II and support for MP3 etc...
    Main reasons for the all-in-one is the look of it, the wife likes that, the reviews that it gets are pretty good, and i am not looking for audiophile sound quality anyway, the reduction in the number of boxes i need to have, the ease of setup etc.
    Was originally looking at an integrated TV like the Panasonic TX32PB50 as i already have a DVD player. But i also want to play music on CD, radio, MP3s etcs, and dont really want a music system and a DVD player etc seperately in the lounge.
    So all in all i am still considering my options but lean towards the new 550 together with a Sony 100Hz TV.
    There is a HIFI and Home Cinema show at Heathrow in September where all the big players will be demo'ing their latest kit so i will probably have a look at everything then and then decide finally!
    Steve.
