Sony KV32FX20 or Panasonic TX32PK2
Discussion in 'General TV Discussions Forum' started by Stone Free, Jun 13, 2001.
Tags:
  1. Stone Free
    Stone Free
    Jun 13, 2001
    871
    28
    London
    +28
    Which of these is the better set and why ?
    I am looking to buy one of these for £800 - £960
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    I have got a Sony KV32DX20 which is very similar to the FX20
    Bad points both
    PAL picture isn't very good something to do with SVM or sharpness - haven't yet cut the wire!
    DX20 Good
    3 Scarts
    DVB-T tuner
    FX20 Bad
    Only 2 Scarts
    Good points
    Very good picture via RGB.
    If you can afford it look at the DX30 this is the DX20 replacement and has 3 Scarts and a DVB-T tuner
    If you only want to watch DVDs the FX20 is fine, if you watch TV, it isn't, neither is the Panasonic, why?
    PAL broadcast material is always in a 4x3 frame so you either have bars, zoom up, or stretch to fit.
    Digital TV on BBC, ITV, and C4 is now largely in widescreen and is also anamorphic like DVD, sometimes broadcast can be as good as DVD. Your TV licence is also paying for BBC Choice and News24, which are free channels. Also the IDTV sets have a better picture than seperate boxes I have found, DVB-T runs a higher bit rate for BBC than DVB-S so if you can get a good signal concider an IDTV.
    If you have Sky I think they can pass DVD RGB through, if you have Ondigital get an IDTV and ask for a CAM then have TWO DTV tuners!
    Picture modes the Sony 50Hz chassis supports the following.
    Wide - DVD and Digital BBC etc
    Smart - for squashing and stretching PAL material to fit W/S
    Zoom - for L/B DVDs eg Star Trek 6 and C4 PAL W/S
    4x3 - for not screen filled 4x3 broadcasts
    14x9 - for BBC halfway house zoom, Smart does this OK
    Well add the DX range to your list. But the FX20 is not a bad TV (but I wouldn't buy any non IDTV) but is due for replacement soon.
    Any other questions ask here!
  3. Stone Free
    Stone Free
    Jun 13, 2001
    871
    28
    London
    +28
    In theory I would love to get an IDTV Widescreen TV as I have wanted one ever since I heard that they were going to be made.
    But unfortunately I cannot afford to spend £1246 to £1500 on a TV
    I have been waiting over a year for flatscreen TVs to get to the £800 - £900 range.
    I cant wait another year to be able to afford the IDTV
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    1) look for discounts
    2) What was interest free credit invented for :)
