Sony KV32FQ80
R
RooneysBoots
Hi there,
I have an FQ80 and the outer edge is out of focus.( 3" on each side). The retailer thinks it may well be adjustable in the service menu. Does anyone know how to access the service menu? Do you think it is possible to correct this from the service menu or does the set need to be replaced?
:confused: :confused:
lynx
I would strongly advise that if you don't know what your doing,leave well alone.Since it's under warranty let the dealer sort it out.If you try to correct it yourself and make matters worse you may find the dealer reluctant to help.
LG SP11RA Soundbar Review Coming Soon to AVForums
