Sony KV32FQ70
Discussion in 'General TV Discussions Forum' started by Baal, Oct 26, 2003.
  1. Baal
    Baal
    Oct 26, 2003
    i was in the process of ordering a panasonic PD30 when i luckily dropped on this forum...and after reading the 'sticky' i dumped this idea :rolleyes:
    i'm now looking at the Sony KV32FQ70 (hoping its not too related to the 75???)
    has anyone any comments on this TV?
    BTW what's a PF2 and is this better than the Sony above?
    Please help me through this minefield Thanks :smoke:
  2. pclarke
    pclarke
    Got the Fq70 and love it.
    No tv is perfect but having been through 1 JVC, 3 PanaCRAPics and a fx68, the FQ70 is leagues ahead. Geomtry is as perfect as I think you will get on a CRT, convergence very good, and pictures consistently good.
    Does suffer from minor red bleed but nothing too bad - don't really notice it. Sound is a bit naff but I am in the process of getting an AV system so not bothered.
    Got mine from JL with 5 year warranty, price matched with Techtronics and got a free DVD player! ;)
    Go get one!!!
  3. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    The PF2 is the Toshiba Picture Frame 2 (model 32ZP38).
  4. Baal
    Baal
    Oct 26, 2003
    take it that this's a good 'un :confused: to be technical :p
    i'm not into TV's but i've got 1500 quid to spend and room for a 32 and just want the best pic for my money's
    i dont care about the sound 'cos i've got that bit sorted and don't care if its digital reciever 'cos i've got a sky box....in fact i don't have any analogue to go in....
    all help is appreciated
  5. PaulJ
    PaulJ
    Hi Baal,
    The FQ70 is the replacement for the FX66, I have one and have been very happy with it.
    The FQ75 was replaced with the FQ80.
    If I had £1500 I think I would be tempted to go for a higher specification model. The FQ70 can be picked up for under £900 now.
    I don't really have any moans about the FQ70, though.
    :cool:
  6. Baal
    Baal
    Oct 26, 2003
    don't want to appear like a clown :clown: but.... :p
    ...the thing is that I don't know what extra i would get with a higher spec
    i wondered around Comet this evening and with the s***ty analogue inputs all the TV's were running all the pictures looked the same :suicide:
    if higher spec means better sound then i'm not interested....i've already got a dolby surround thingy sorted :D
    what should i look for in a higher spec television?
    BTW thanks people for replying:D
  7. monsieurblack
    monsieurblack
    Oct 6, 2003
    550
    England
    +22
    hiya baal :)
    i'd go for a loewe set if i had the funds [just got a sony 32fx68 :cool: really pleased...]
    i'd do a search on the forums here for the loewe threads as pretty much anything done by them is about as good as you're gonna get :D :) [along with b&o ;)]
    good luck in your quest :)
    keep us posted
    monsieurblack
  8. mansell
    mansell
    Feb 11, 2002
    914
    28
    Bristol
    +39
    Hi , after one sad and frustrating year getting my Panny PB50 replaced three times I gave up and bought the Sony FQ80
    This baby is very similar to the FQ70 apart from more bells and whistles .
    I can say for sure you wont be dissapointed with the Sony ,in my opinion it's much better than the panny in terms of PIC
    Just do a search for this set (FQ80)on AVFORUMS , you wont find that many links when compared to the Philips and Panny sets , that speaks volumes as most of these threads are about faults and general bad points .
    As a X PB50 owner I dispair when I read about all these PD30 faults .
    go for Sony mate !
  9. Baal
    Baal
    Oct 26, 2003
    thanks the fq80 looks surweeeeet :cool:
    i'll have a read up ...and as for the loewe monsieurblack i'll dig summat up and read it :smoke:
  10. freeross
    freeross
    Connect a PS2 to the fq70 and the pictures are all fuzzy - whats that all about?
  11. aliasnow
    aliasnow
    mmmm....
    see some post ago... that's vertical smearing
    I know it very well, it can't be fix
    forget you've seen that and you'll live happy
    and use a s-video instead rgb cable for ps2
    take care
