Sony KV32FQ70 vs. KV32FX68
Discussion in 'General TV Discussions Forum' started by Bilalc, Dec 13, 2003.
  1. Bilalc
    Bilalc
    I'm currently looking at these two sets, trying to decide which one to get. The FQ70 is a bit more pricey, but I know little of the difference between these sets. Which one you would you recommend? And why? I'm after pros and cons with both sets... and and all help is highly appreciated :)
    And also, what "system", or technique if you like, does these Sony tv's use to undo the 100Hz TVs "Jaggies" problem?
  2. hmsq
    hmsq
    Nov 3, 2003
    764
    London
    +50
    well after receiving the Sony KV32FQ70 i found out that it has a manufacturing defect, the screen on the right side slumps down and when you watch tv it become a really annoying factor and spoils it, specially as the only different from the fx68 is pip and vertical stabilizer, i would go for the fx68
  3. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    The FQ70 has more processing applied to the 100hz picture. I read in one magazine that they preferred the FX68 as it looked more natural. I also know many people on here are very happy with the FX68 and it's the one I'd personally go for.
