Sony KV28LS60 RF interferance problem
Discussion in 'General TV Discussions Forum' started by Greamec, Feb 28, 2003.
  1. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
    Here is my setup , AV1 = Sky box, AV2 = Xbox, AV3 = VCR, AV4 = Computer via svideo.
    When I plug the RF cable into the television from the normal arial so that I can get local news broadcasts I can watch BBC 1,2 ,ITV Cannel 4 fine but if I switch over to watch sky I can see ghosting on the picture from the RF. unplug the RF and it goes away.
    Could someone help me to resolve this?
    Regards Greame:smoke:
  2. testcard
    testcard
    Have you tried taking your RF aerial lead from the wall into you Sky box, from Sky box into VCR, from VCR into TV RF socket. This I think is how SKY suggest wiring up the aerial. Then you can watch either SKY, or press TV on SKY remote and watch RF local TV. This might avoid crosstalk.
  3. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
    Just gave it a try but it is still ghosting, I just do not get it I did not get this with my old television which was crap compared to this one.
    Greame:thumbsdow
  4. testcard
    testcard
    Are you using decent quality, screened SCARTS for your connections?
  5. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
    Hi I am not but They all look the same to me how do you tell good from bad. I was just looking on ebay at them but do not know which is best wouldyou have a look and point me in the right direction?
    Cheers Greame
  6. testcard
    testcard
    These are makes to look out for: IXOS. Thor and Monster. Good quality, screened, SCART lead can reduce crossstalk and signal leakage from other leads, and gold-plated connectors can make a tremendous difference to picture quality too.
    At the top of this forum page, click on "Search", type SCART leads into the search box, and you'll find numerous threads with reviews and recommendations on which SCART leads are good.
    It might be worth unplugging everything, then re-plugging one lead at a time to see if the problem suddenly appears with a particular configuration.
    Could this be a problem caused by the AV3 output? Anyone else have any suggestions?
  7. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
    Just got my new scart leads and the problem has gone , well worth the extra cash.
    cheers testcard:clap:
