Sony KV28ls35
Discussion in 'General TV Discussions Forum' started by starman, Jan 17, 2003.
  1. starman
    starman
    Ive just bought a sony 28' widescreen tv and im having major problems with sound amplification.. Now ive plugged my amp via phono leads into the tv phono sockets and switched off the tv speaker volume. I turned on the amp and even on full volume it is really low.. the amp is 300 watts so im confused....:( any suggestions?? Should i try a scart to phono lead?
  2. fernando
    fernando
    That´s exactly what surprised to me the first time I connect my set to the HI-FI chain.
    What you can do? try this. With the RC of the TV you can manage the volume of your external amp when "tv speakers" are off. Put the volume loud and then you will have an almost normal output. Once you returnm to the TV´s speakers output you will have a normal level.
  3. si325i
    si325i
    i have one of these TV's too.
    do you have two lines on the screens about 1/3 and 2/3 up.
    very thin black line. can only see it when back ground is white.
    and did you know AV1 is RGB ready and AV2 is not??
  4. fernando
    fernando
    Sorry but no extrange lines on my set. Maybe you might visit the Technical service.
    With respect to the ext scarts. To my knowlegment, AV1 is both RGB and composite capable and AV2 admits S-video and composite video signals.
    Is there any way to play an external RGB signal via AV2???
    Saludos
  5. si325i
    si325i
    Thanks Fernando, have you looked close @ your TV about 3feet.
    Thankyou, but i got two lines for sure. boo
  6. Squirrel God
    Squirrel God
    The LS35 only has ONE RGB-capable Scart, which is AV1.
  7. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    :eek: What amp is it.
    As for the lines, they are present. It is a well documented issue. I have a 19'' Sony monitor and they are present on this also.
  8. si325i
    si325i
    Thanks, i feel better now.
    What a great TV, i've got a HTLS5A with a DVPNS405 dvd player.
    sound great.
  9. Christ
    Christ
    Dec 15, 2002
    275
    Yorkshire
    +18
    As Lynx says the lines is a feature of every Trinitron Tube, the lines are actually a shadow cast by 2 very thin wires. You can only see them on a white background.
  10. fernando
    fernando
    I´ve checked this morning the problem of the thin black lines with a white screen and I can say that can´t see them.
    My set is a 28KVLS35- B and it was bought in spain three months ago.
    Do you think that they will appear with the time???
  11. Squirrel God
    Squirrel God
    No, they are there but it's good that you can't see them. I can't see them on my Sony TV either. Do not try and look for them - it's better if you can't notice them :)
  12. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,886
    3
    48
    +79
    Yes,this worked for me,as it by-passes the audio out on screen option.
