sony kv28hx15 probs
Discussion in 'Televisions' started by vince_vega, Mar 18, 2005.
  1. vince_vega
    vince_vega
    Jul 29, 2004
    720
    +9
    hi all, i have just noticed a slight problem with this wonderful tv. There seems to be a dark line about 3 inches from the bottom of the screen which is just visible when the pic on screen is very light. I hadnt noticed it until i watched the empire strikes back hoth scenes, the line is just above the black bar on widescreen presentations. Has anyone noticed this before and if so how can it be fixed? thanks
  2. timbo_bobcat
    timbo_bobcat
    Aug 13, 2004
    No problems here...
  3. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi, as it's a Sony I guess it is fitted with Sony Trinitron crt. If that's the case then I would guess you are seeing the 'shadow' of the very very fine wire that crosses the crt behind the faceplate that keeps the vertical fine wires in position. This is perfectly normal on any Sony Trinitron CRT, in fact, depending on the screen size you will see more than one of these very fine lines crossing the screen - two or three ? This is inherent in a Trinitron crt and at normal viewing distances you shouldn't see them. Have a very close look at the screen when its displaying a bright picture. Just my thoughts. Regards, yt.
  4. vince_vega
    vince_vega
    Jul 29, 2004
    720
    +9
    and now something else weird has started happening! about 3 times an hour a clicking is heard from the back of the screen and the whole screen flickers and goes slightly darker for a split second before righting itself, its bugging me now so any ideas what the problem can be guys?
