sony KV28FX68 problem, can anyone help?
Discussion in 'General TV Discussions Forum' started by woods139, Jul 21, 2004.
  1. woods139
    woods139
    Hello, I have had my Sony KV28FX68 television for nearly three months and up to very recently it's been fine (I got used to the buzzing). But in the last few days a problem has started to happen after the television has been switched on for 15 to 20 mins (approx.). The problem is that a horizontal thin line appears intermittently for a split second on screen, it can happen anywhere on the screen (the line always covers the hole length of the screen). This then happen usually once a minute (sometimes more) for the rest of the time the television is switched on for. This problem happens during the analogue signal and also when using freeview/dvd/vhs through any of the 3 scart inputs. Sometimes I can hear a noise that sounds like static when the problem happens.
    Does anyone know why this has started happening? If so does anyone know of a setting in the menu or service mode settings that could correct this problems?
    [Thanks]
  2. Alan D
    Alan D
    Rather than something that can be tweaked, this sounds onminously like a fault - maybe power supply related. I'd call your dealer as soon as possible and demonstrate the problem.
