jasonbosley
Had the purity problem fixed on my Sony KV28FX65U around a week ago ( this was the second attempt !)
Engineer Report came with the set :
"Resoldered CN662, installed Latest software and set up Geometry and beam landing"
The purity problem has been fixed, something I thought would never be put right, my problem is that now I notice a slight flicker on all sources.
It does not seem to make any difference when choosing between refresh modes. It's as if it is stuck in 50 Mhz mode even when changing to 100Hz ("advanced or Digital +")
Before the set went away, yes there was the purity problem but going between normal and 100Mhz modes made alot of difference in picture quality.
Any ideas ? Would the job sheet suggest a repair which would cause this symptom ?
Any advise greatly appreciated
