Sony KV28FX65 Service Menu Hack
Discussion in 'General TV Discussions Forum' started by Gliese 581c, Mar 9, 2002.
  1. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,840
    On AVForums
    +580
    Does anyone know the hack to get into the service menu of the Sony KV28FX65 tv set ? I need to make a couple of adjustments.
  2. gges
    gges
    There is no 'hack' - only an engineers service menu which shouldn't be entered by non-qualified personnel. It is very easy to adjust something inadvertently and make a real mess. If you have problems I suggest you contact a local Sony specialist who should be able to make the necessary adjustments for a reasonable amount.
    Cheers, gges.
  3. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
  4. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,840
    On AVForums
    +580
    Thanks for the www site simon1.....and for not treating me like a ****in kid.
    Yeah gges..that was directed to you
