Sony KV21LS30 always goes into 16:9 on AV1
Discussion in 'General TV Discussions Forum' started by Jon Weaver, Feb 6, 2002.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,188
    Born in Bristol but now in Newport, (for my sins)
    +735
    This looks like a bug, but I wonder if someone could confirm that they see the same.
    When I select AV1 (RGB) that TV always goes into 16:9. This is strange as its a 4:3 TV! This happens even when there is nothing connected!
    Could someone take a look at theirs?
  2. brattle
    brattle
    Oct 12, 2001
    108
    16
    Bedford
    Mine does the same. I just switch it back :).
  3. yashiro
    yashiro
    You can turn this 'feature' off via the service menu.
  4. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,188
    +735
    I just happened to spot this reply by chance... Please can you tell me how?
    I know how to get into the service menu, but what option needs to be changed to 'fix' this?
  5. obsoleteKit
    obsoleteKit
    Apr 10, 2006
    7
    3
    Berkshire
    Hello
    I'm resurrecting this old thread in the hope that someone might have the answer to the orriginal question. My KV21LS30U is a 4:3 set. How do I stop the TV going into 16:9 mode when AV1 is selected and an RGB source is connected?
    I never want or need the TV to go into 16:9 mode. I have even tried cutting pin 8 of a scart cable but it has not helped.
    I can get into the service menu, but I cannot understand the codes in the options lists. Perhaps some kind soul might point me in the direction of a docment that holds an explaination of these long lists of codes?
