Sony KV-A2542U
Discussion in 'General TV Discussions Forum' started by Paden, Nov 28, 2001.
  1. Paden
    Paden
    Jul 27, 2000
    562
    +17
    Hello all!
    My brother's has this set & today when it was switched it had no picture & the stereo A/B indicators on the front of the set were flashing alternately.
    Any ideas?
    Cheers, Paul.
  2. lbstevens
    lbstevens
    hello
    im sorry i cant help u with yr problem but can u or anyone else help me with mine.
    I too have a sony kv-a2542u tv and would like to know can u manually re-tune using the front control panel buttons as i have lost my remote and user manual. I have tried Sony Service Dept but they said tv is too old. Great! (It still works though)
    Any help or suggestion would be appreciated.
  3. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Paden,
    This is usually an indication for a technician, hopefully guiding them to the area of the fault.
    It's not something you can fix yourself. :thumbsdow
    Sorry.
    lbstevens,
    Are you aware that you don't need the official Sony remote?
    There are plenty of cheap universal remotes available.
    As a bonus, you'll get Teletext back after you've done the tuning!
    Good luck. :smashin:
  4. lbstevens
    lbstevens
    Is this the only way to retune channels, using a remote control. I can get text using my Skyplus remote will I be able to retune channels using this remote.
    lbs
  5. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    I'm not familiar with this TV, but most can be tuned using the front buttons (if you can work out how!).
    Is there a Menu button? If so, that would be a good place to start.
    I doubt you can retune using the Sky remote. This is just for basic TV functions.
    Sorry I can't be more help (and sorry to Paden for hi-jacking your thread!).
