Sony KV-32FX68 Vs Toshiba 32ZD26
Discussion in 'TVs' started by moochoo, Dec 28, 2003.
  1. moochoo
    moochoo
    ive been looking at buying a new TV for a while and have narrowed it down to these two models.
    my main usage for the TV would be DVD's and games.
    i currently own a SD-330E DVD player, Xbox, PS2 and a gamecube.
    which of these two TV's would give me the better picture quality?
  2. KTF
    KTF
    The Toshiba would give you Component in straight from the DVD v Scart for the Sony.
    Both are great sets though. I have the Toshiba - and the 330E DVD - and am happy with the compination.
  3. eeper
    eeper
    Dec 4, 2002
    61
    UK
    Is component better than RGB scart?
  4. phenom2003
    phenom2003
    Most people would agree that there is no difference between the two (component and RGB) at 480i and 576i. However one advantage that component has that scart doesn't is that it can do HDTV and proggresive scan, so with a prog scan player and TV, component would be better.
  5. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Own the 28" version of the Sony, outstanding picture quality, excellent build quality...
