SONY KV-32FX65U & DAV-S500 PROBS .
Discussion in 'General TV Discussions Forum' started by DARRYLDUNN, Mar 29, 2005.
  1. DARRYLDUNN
    DARRYLDUNN
    I RECENTLY DECIDED THAT I SHOULD UPGRADE THE CONECTION FROM MY DVD TO THE TV . UP UNTIL NOW I HAVE BEEN USING THE HORRIBLE YELLOW INTERCONECT SUPPLIED WITH THE SYSTEM (MULTI-REGION) WITH NO REAL PROBLEMS APART FROM THE FACT THAT IT IS SLIGHTLY UNSIGHTLY HAVING IT ENTERING AV-4 ON THE SIDEFLAP OF THE TV.
    I RECENTLY PURCHASED AN IXOS S-VHS & 2 RCA TO SCART 137AV.
    PICTURE IS NOW TERRIBLE WITH GHOSTING AND PURPLE TINGE TO THE PICTURE EDGES WITH THE MAIN PICTURE NOW IN BLACK AND WHITE WHEN PLAYING A NTSC DISC.
    ANY IDEAS ?
    PLEASE BE GENTLE AS I AM VERY MUCH A PLUG AND PLAY TYPE OF GUY .
    MANY THANKS DARRYL :lease:
  2. JayCee
    JayCee
    Jan 20, 2004
    21,756
    Lanarkshire
    +2,235
    Do you have the Dvd player set to output S-video? or the Scart socket on the Tv configured to input S-Video?....check your manuals, the scart socket you are plugged into may not accept S-Video......either option will give a b&w pic if incorrectly set.
    BTW it is considered bad etiquette to "SHOUT" :lesson:
  3. DARRYLDUNN
    DARRYLDUNN
    Apologies for SHOUTING , force of habit from work reports which are required in capitols ???
    Should have mentioned that PAL dvd's play fine through same set-up.
    t.v. appears to be ntsc compatible as it always plays fine through the old dodgy yellow lead
  4. Kryters74
    Kryters74
    Jul 23, 2004
    239
    London
    +7
    Do you have to use the s-video out? Have you tried a standard scart cable from the davs500 to the TV? I have the same TV and it plays NTSC disc's fine from my pio575a, but it is connected to the RGB scart socket...
  5. DARRYLDUNN
    DARRYLDUNN
    Sony dvd's don't appear to use scarts .
    Not sure about the latest models .
  6. Kryters74
    Kryters74
    Jul 23, 2004
    239
    London
    +7
    Perhaps it is time to upgrade to a proper seperates system? Trust me they do sound a lot better than the all in one kits.
