Sony KV-32FX20E Service Menu
Discussion in 'TVs' started by xprezz, Jun 1, 2005.
  1. xprezz
    xprezz
    hey anyone know how to get into the service menu of a KV-32FX20E?
  2. ventoboy1000
    ventoboy1000
    :hiya: Hi Xprezz, try the following,
    1. Put the tv in standy mode.
    2. Press the following buttons on the remote control
    i+
    5
    Volume +
    [ ] Blank square button usually on the top of the remote control.
    The tv then should display TT and you are in service mode.
    To exit, press 00.
    Hope this helps !
  3. xprezz
    xprezz
    That did the trick. thanks a bunch.
    Now I just need to figure out how to fix my geometry. Screen droops slitghtly on the left.
