Sony KV-32FQ75u / warranty
Discussion in 'General TV Discussions Forum' started by la_guitars, May 21, 2005.
  1. la_guitars
    la_guitars
    May 21, 2005
    27
    I've been told my 4 year old Sony KV-32FQ75u is beyond repair - problems with the tube.
    Luckily I purchased from John Lewis with its 5 yr warranty. The JL store have told me they will offer me a replacement early next week.
    Has anyone been offered a replacement set from JL - are they fair in what they will offer ?
    What should I be expecting in getting a replacement for my Sony ?
  2. Mr Grumpy
    Mr Grumpy
    Jan 12, 2005
    377
    TBC
    +9
    Well I would be surprised if John Lewis could get hold of a replacement unit for you, though there may be a handful of refurbs around I guess. My biggest concern would be what sort of quality replacement you might end up with as this set seemed to be plagued with problems (something I only discovered after i had bought my ex demo unit from the late Techtronics). I had a heck of a job getting the aforementioned company to swap my first set when it died on me, and the current set has pretty poor geometry at the left/right extremes - particularly noticeable with text such as the Sky EPG.
    Basically do not accept anything that isn't working perfectly, if you are real lucky they *might* swap it for a newer equivalent model maybe.
  3. la_guitars
    la_guitars
    May 21, 2005
    27
    thanks - been offered by JL a credit voucher. got to go and see tv's
  4. Mr Grumpy
    Mr Grumpy
    Jan 12, 2005
    377
    TBC
    +9
    You must be very glad that you bought that 5 year warranty :thumbsup:
    Hope you soon have a nice fully functioning replacement.
  5. la_guitars
    la_guitars
    May 21, 2005
    27
    the 5 yr warranty was included with TV fron John Lewis.
    any suggestions what i buy with £1500 - do i go plasma/ lcd or stick with CRT
