Sony KV-32FQ70U help
Discussion in 'Televisions' started by sunderland, Sep 24, 2004.
  1. sunderland
    sunderland
    Oct 29, 2003
    4,518
    83
    northeast england
    +242
    well i was just wondering how you can adjust the sharpness on this set. ive been into live and personal and movie and it doesnt let you change it in any of them. anyone got one of these. if they could let me no cheers. :lease:
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,549
    Galactica C.I.C.
    +199
    Personal should be the one setting that allows you to change
    Contrast
    Colour
    Birghtness
    Sharpness.
    Are you saying it will not allow you to change it or that there is no sharpness option there at all?
  3. sunderland
    sunderland
    Oct 29, 2003
    4,518
    83
    northeast england
    +242
    it lets me change
    contrast
    colour
    brightness
    but not sharpness that is greyed out
  4. ventoboy1000
    ventoboy1000
    Hi Sunderland, I use to have this set and the reason why the sharpness is greyed out is because it cannot be adjusted when watching something through "RGB".
    If you select an analogue channel, that comes through the normal tv aerial it should let you adjust the sharpness.
    Hope this helps !
  5. sunderland
    sunderland
    Oct 29, 2003
    4,518
    83
    northeast england
    +242
    thanks ventoboy1000 that did the trick cheers to all
